doesn't that stuff become VOC when you heat up the car under the sun?
are you referring to the bird crap? or the chemical spray?
Slap a folded wet one on the dropping and wait 30 seconds or more before attempting to wipe. If there's no nearby water source you'll have to plan ahead and tote a spray bottle with you.
😱 That is so bad for the clearcoat, you are marring and swirling that bish up.
I do not use any detail sprays, I wash my car weekly. Bird poop would be the only reason I use a spray.
still validA friggin tarp. You don't want that shit landing on your car.
Believe me, no one's more careful about swirlies than I. But we're talking hose-less conditions here. Light pressure, wipe once then turn to clean side and wipe again. I'd rather not remove droppings without a hose but sometimes you have no choice but to risk superficial marring to get droppings off as quick as possible.
I rarely wipe my car without a stream of water running across it and a wool mitt. If using the shop towels I posted above, I rinse off the towel after every wipe. That's how I roll.
Water-less conditions you say...Believe me, no one's more careful about swirlies than I. But we're talking hose-less conditions here.
