Staples has a KDS VS-21e 21" Monitor for $525.49.
1. Price match these guys at $427.53
2. Use a $40 off $200 coupon code.
Total after price match and coupon is $387.53. Not bad for a 21" monitor.
21"(19.9"VIS) HIGH-PERFORMANCE COLOR MONITOR
The VS-21e is designed for imaging and CAD/CAM/CAE professionals who want maximum performance from today's technology. A powerful tool for high-end graphics, production, scientific and engineering design applications, its advanced features deliver sharp pictures, crisp colors and precise lines with virtually no eyestrain. The VS-21e is fully protected under KDS' exclusive KARES program, insuring peace of mind in addition to excellent performance.
Cathode Ray Tube
Size : 21-inch diagonal measure (19.9" viewable)
Screen : Anti-reflective, anti-static coated
Dot Pitch : 0.22(H) Horizontal Dot Pitch .25 Vertical mm
Phosphor : P22
Video
Input : 15 pin D-sub
Dot Clock : 230 MHz (max)
Transient Response : < 5 ns between 10-90 percent
Synchronization
Polarity : TTL pos/neg
Frequency : 30-117 kHz (horizontal)50-160 Hz (vertical)
Retrace Period : 3.5 µs (max horizontal)600 µs (max vertical)
Raster Specifications
Display Size : 380±4 mm 285±4 mm
Maximum Resolution : 1920 x 1440 @ 75 Hz
Optimal Resolution : 1600 x 1200 @ 85Hz
Electrical
Voltage : 110-240 VAC, 50/60 Hz
Power : < 160 W
Inrush Current : 30 A @ 100 VAC, 60 A @ 200 VAC (max)
Physical
Operating Environment : 0-40 °C (32-104 °F)5-80 % humidity, NC
Dimensions : 485 x 527 x 506 mm (W x H x D)19.1 x 20.8 x 19.9 inches
Weight : 33.5kg (73.7 lbs.) Gross: 28.5 kg (63.4 lbs.) Net
Features
General : Multi Language On-screen, digital controlVESA DDC 1/2B Plug & PlayAuto degauss
User Controls : Contrast, brightness, H/V size/position, color temperature (9300/6500) RGB drive, H/V pincushion/H trapezoid/H/V convergence, raster rotation, degauss
Regulatory Approvals : UL1950, CSA, TUV G/S, FCC Class B, DHHS, MPR-II, TCO 92, ISO 9241-3, SEMKO, DEMKO, FIMKO, NEMKO, CE, EPA Energy Star (TCO 95 Optional)
MSRP : $765.70
Warranty : Three year full warranty
Cathode Ray Tube
Phosphor : P22
Video
Synchronization
Electrical
Power : < 160 W
Physical
Features
MSRP : $765.70
