KBPS question for audio!!
4fingerwu1
Well I accidentally had the setting on the windows media player at 64kbps when I recorded my cd collection -
2 questions- How big is the difference between the quality of different kbps settings and what would you recommend I rip at?
One more - is their anyway to change from 64kbps to say 192 without going back and re-ripping every cd?
Thanks
4Fingerwu1
"How big is the difference between the quality of different kbps settings and what would you recommend I rip at?"
Most people recommend 'at least' 128k for Music. 64k 'may' be acceptible for some plain speech (ie: books on tape or something). Variable bit rate is definately a superior choice is space is of concern. Checkout r3mix.net .
"One more - is their anyway to change from 64kbps to say 192 without going back and re-ripping every cd?"
Well yes you can convert your 64k tracks to 192k but the quality won't increase. You can't pull the missing data out of thin air. Just like you can record a mono track in stereo but it won't sound any better (you'll simply have 2 channels of mono). (BTW That'd be there not their or they're).
Thorin
