thilanliyan
Which fan would be better to use with the Swiftech MCR120-QP radiator?
The Kaze Ultra (38mm thickness) has a huge center hub so I figure there would be a large dead spot on the radiator (fan shroud not an option) but has higher static pressure. The particular ultra kaze I got only flows 44cfm but is dead silent (a bit of a priority). Would having the fan in a pull configuration be better for the deadspot issue?
The slip stream (25mm thickness) flows 68cfm, is louder (24dba vs 19dba for the kaze ultra) but has lower static pressure.
I also have some Yate Loons I could use.
I could put 2 of either fan in push/pull but would prefer just one in a pull configuration to pull air out of the case (the rad will be internal). Which brings me to another question: push or pull for radiator fans?
