Actually I ran all those benchmarks prior to Kaveri's embargo is lifted. Only translating them in English takes that much time thank to my poor English ability. Anyway, let's have a look:
My review consists of two parts - Part 1 is for Processor Graphics inside Kaveri while Part 2 is being planned to deal with Kaveri's coverage at the domain of traditional CPU as well as its HSA features. Today I will show you the former one.
Test hardwares are as follows:
Before the test begins, I estimated Kaveri's Processor Graphics performance by using VGA calculator I designed. It's a simple, first-order fractional equation consists of GPU's compute performance(number of shader * core clock), texture fillrate(number of TMU * core clock), rendering performance(number of ROP * core clock) and VRAM bandwidth(bitrate * VRAM clock) as its terms. (further about this equation, see this: http://udteam.tistory.com/535 - by using this, I speculated that Hawaii will be faster than GTX TITAN while full-blown GK110 will also retake the crown from Hawaii even prior to Hawaii's release) First result for A10-7850K, which has 8 Graphics Core(= 512SP/32TMU/8ROP) within it.
Second is for A10-7700K / A8-7600 both have 6 Graphics Core(= 384SP/24TMU/8ROP).
Well, the results suggests that Kaveri's Processor Graphics is virtually competitive to entry level discrete graphics card. At the same time, however, it also implies that +128SP is not actually helpful (difference between 7850K and 7700K/7600 is less than 7%) and this means performance hesitator is not SP/TMU part. Rather, ROP partition and poor memory bandwidth are more likely. So why AMD cultivate that much amount of SPs despite all? I think, AMD's intention is aimed for Post HSA era. Huge amount of SPs are employed not only for graphics acceleration but also as compute resources, thus to allow them a whole "856 GFLOPS" in one chip. (further will be dealt in Part 2)
Well, the intro was too long. Let's see the numbers!
All tests are done at 1280x720(HD) / 1600x900(HD+) with highest possible graphics quality settings.
(You can see original results from my blog: http://udteam.tistory.com/611)
1. 3DMark 11
(Entry / Performance Preset)
2. 3DMark 13
(Cloud Gate / Fire Strike)
3. Aliens vs Predator
(Texture : Very High, Shadow : High, AF x16, SSAO On, Tessellation On, Advanced Shadow On, AA Off)
1. 3DMark 11
2. 3DMark 13
