k8t800pro, sis 755...both use pci bus for onboard lan?
Gulzakar
so my choices are the sis 755 chipset or the k8t800pro.
I had a question regarding the onboard lan...I know most of the k8t800 boards utilize the pci bus for lan, but I was wondering how the sis 755 chipsets are setup?
anyone have any ideas?
any ideas on some nice overclocking boards?
Wahsapa
3,004
im not sure but i think the sis also uses the pci bus, iv never seen anything to indicate otherwise. i beleive the sis chipset has a faster northbridge-southbridge link tho... and thats about it.
Peter
9,640
Neither has to - both the SiS and VIA south bridges have an integrated 10/100 MAC that does _not_ eat away from PCI bandwidth. It's up to the board vendor whether they use that, or choose to put a PCI based MAC/PHY solution on.
If it's going to be Gbit Ethernet, then it'll have to be on the PCI bus until the new southbridges (SiS 965, VIA xxxx) are here.
orangat
1,579
I would go for SIS755. I've had too many issues with VIA over the years.
Mostly southbridge problems with UDMA, pci bus mastering/latency/bandwidth problems.
They may have finally solved all that with the pro version but I'd still stay away.
Why don't you consider the NF3-250Gb chipset??
Gulzakar
I'm going back to win2k and I remember past expereinces with the nforce boards and crappy ide drivers...the standard win2k and winxp ide drivers left a lot to be desired. :)
