K8N-E Deluxe No POST With CPU Installed
MrOuijaAK
I just recently purchased an Asus K8N-E Deluxe motherboard and an AMD Athlon 64 3200+ After installing everything and trying to boot up the computer refused to POST. No video, no POST error messages. So I slowly started taking parts away. Finally getting all the way down to just a motherboard and processor. Still nothing, finally I took the CPU out and just booted the motherboard alone and got a POST error message telling me No CPU Installed.
After calling Asus tech support they told me I probably had a bad processor and to get it replaced. So I called up newegg and got my CPU replaced. Well the replacement came yesterday and it still doesn't work.
I tried googling for K8n-e no post and I found one other person with this problem. It was unresolved there and he had actually sent the motherboard back to Asus for a replacement and they told him it was working fine and returned it to him.
So anyone got an idea?
You'll need the CPU, memory, and video card to post. Try your motherboard outside the case on cardboard like shown here, and make sure your ATX12V cable is plugged in, people overlook it a lot for some reason. Don't plug in any drives, or any case wiring except the power button.
It will also help if you give a complete list of all your hardware, as specifically as possible, including the brand and model of the power supply.
Yeah my ATX12V cable was plugged in. And I tried this all outside of the PC resting on the box. I tried it with Memory, CPU and Video Card. Got nothing, no post error messages. I then took out the video card and still no error messages. Then out came the memory, still no Post errors. It wasn't until I removed the CPU, that I finally got the Post message of "No CPU Installed"
BFGTech GeForce4 Ti4600
Asus K8N-E Deluxe
AMD Athlon 64 3200+
2x512MB Centon PC3200
480w No name power supply came with Logisys case. Tested on another setup and it ran fine.
Believe it or not, one issue that crops up every so often is that people manage to put the CPU into the socket the wrong way 😱 I know this is "well DUH!" but it is in the socket this way, right?
Also, if you have another name-brand power supply in the 300W+ range, like Fortron, Enermax, or Antec, maybe humor me and try it 🙂
Yeah I double checked both times to make sure I didn't bend the pins and put the cpu in wrong.
I don't currently have another power supply around to test it out on. That's going to be my next purchase for this rig in the next few weeks.
The power supply was my initial assumption until I started doing some googles on the K8n-E and found a lot of people having problems with them for various reasons. Plus one guy with the exact same problem as me (but no solution.
Replaced the PSU with an Antec TrueBlue 480. Booted up no problem. After removing the PSU from the case it came in I found that it weighed less then a box of Kleenex.
