K8n-e deluxe hardrive problem
Duckasso
I have a K8n-e deluxe hardrive problem.
the problem is i have 2 hardrives plugged into the black sata drive on the motherboard.one of them with windows xp and the other with files(non raid) Now i got a 3rd one and this is also sata drive i plugged it into the red plugs (sata raid ). The problemn is i cant find the harddrive exept for in the bios<---boot<---hardrives, and in the device manager in Silicon image Sil 3114 Softraid 5 controller you can se that it sees one disk but i cant do anything with it :S
What to do now ?
i only want the 3rd drive to be a slave drive like the 2cond drive the bios cant detect it in the bios as ide master ore slave i really dont now what to do now and www.asus.com has nothing about that:Q
Pssst! You have to install drivers forthe Sil Controller if not done, and look inHard disk management, under computer management, in setting/administrative tools...
I am not using the ports currently, but I want to make sure that I have all of the drivers loaded now anyway...
I downloaded the driver from ASUS. Is it any different than downloading it from the silicon website?
