Started working on putting together a system and I ran into this problem. I had the motherboard in another case and it worked fine for a week, I bought a Enlight case with a 300 watt power supply and placed the board in it. I aslo installed a Seagate 60 gig hard drive. It posted fine and I ran Fdisk I then rebooted and started formating the drive (it did seem really slow but I figured 60 gigs would take a while) after formating I reset the computer and nothing happens (no beeps no video) and the power switch will not turn the system off. I have reset the bios and removed all the drives with the same out come, replaced the memory and video card no change, The power switch will turn the system on but not off. thanks for any help.
ECS k7s5a
amd xp 1700 with stock hs/fan
256 megs kingston pc2100 ddr
seagate barracuta 4 60 gig
STB velocity 4400 apg 16meg (saving money for a new card )
thanks again for your help
ECS k7s5a
