I built a system early last fall with ECS K7S5A, 1.4G Athlon (boxed), Crucial 256M PC2100, MSI GeForce GTS, Win 2000, ATX, etc. It has run flawlessly since then.
It started dying this weekend. Sometimes it wouldn't start, sometimes it would, sometimes it would shut itself down.
That flakyness continued as I tried to isolate it, leading me down the wrong paths somtimes. It seemed to be my CD-RW drive screwing up the IDE bus at one time, but that is out of the picture now.
This flakyness made me think it was the power supply, based on my experience with another system. I replaced it, but no luck. I'm down now to MB, CPU, Memory, and video card. When I power it on, the fans run but there is no other sign of life; no beeps, even the power LED doesn't come on.
1. Should this system power up without a video card? There are not POST beeps with or without the video card.
2. This AMD processor/fan/heatsink in a box has the "peel and stick" type of connection from the processor to the heatsink. The doc says this is a one time deal, and the heatsink can't be reused. Looks like I have to remove the heatsink to flip the lever on the CPU ZIF socket, so am I correct that I can't re-seat or swap the CPU without trashing the heatsink? Will there be goop on the CPU that I need to clean off?
3. Any way to isolate this further without buying lots of spare parts? The local shop will charge me $30 for each half hour of service, which will be mostly swaping parts, they said.
