- Jul 16, 2001
- 7,571
- 178
- 106
Just got a used k7s5a off the FS/FT forum. It's slightly buggy and I think it could use a bios update. Aside from that, I'm not able to get the AC97 C-media onboard sound to work. I tried installing from the ECS site. The problem appears to be that during the hardware install, it can never find the files "kuser.dll" and "ks.sys", which wind up being in windows system folders I have to manually point to. Then I get the whole these drivers have not been certified by microsoft blah blah. Which is odd. Are the two files borked or am I getting the wrong sound drivers? I wish I had the cd
Any help is appreciated.
As an afterthought...I'm using one of those 60 gig maxtor drives that were going for $18 at OD a week ago. I had initial trouble trying to install windows. It'd freeze before it even got to the partition page. I pushed the IDE ribbon more tightly into the HD (it doesn't seem to want to stay in) and that got me through installing windows. But upon first boot, I couldnt get much farther than the welcome screen. It took 2-3 reboots to finally get into windows. The slight bug I mentioned above is explorer crashing a lot. Which is actually leading me to believe that the flaky IDE connection with the HD resulted in a flaky install of XP...would this perhaps be why my kuser and ks files are "bad"?
