Hi All,
It seems like there are view ECS K7S5A problems around here so I will add another one.
It is pretty simple, when I choose "SHUT DOWN" options in windows 2K to turn off my machine, the computer powers down but then instead of turning itself off it reboots (sort of like a plane running out of runway then taking off again). Any ideas why this thing is happening? I have an XP1600 with 512 PC133 Ram inside it running on ANTEC 300W PS (check rig specs).
Someone suggested that the powere supply may have something to do with it but I never got a solution. At the beggining when I assemled the computer everything was perfect but after a while this problem occoured. Now I have to wait untill the comp turns itself off in order to press the button manual to shut it off (before it gets into windows again).
Any ideas? IF so plsease private message me so that I can check the answers b4 this thread gets pushed to the very end and deleted.
Many thanks.
Many thanks.
