I have a gigabyte ga-5ax motherboard with the jumpers set at 5*100. For some reason, although it shows the speed being 500mhz when it first begins to boot up, when I get into win2k the speed is only showing up as 250. I've double checked the jumpers and have the latest bios (fa3). I've also run some diagnostics which also show the mhz as 250. These tests show that the multiplier is 5, so the bus speed is getting cut in half (to 50) somehow. This is also supported when I run a memory diagnostic and get results half of what they should be. If anyone has any ideas or bios settings I can try I'd be greatful. thanks.
dave😕
dave😕
