86waterpumper
Alright I don't exactly know which forum is best for this so I will stick it here. I have recently built a htpc with biostar a880g+, & 5200 regor cpu. I am happy with the cpu. I have played with k10stat, and am able to run stable at 2.5ghz (218x11.5) on 1.0125 vcore! I can run 400mhz low as .68 but since it has no effect on wattage I run it at .70. With this setting, the max draw is around 70.5 to 71 watts under full prime 95 which is great. However, the idle consumption stinks...it is pulling 49 or 50 watts on idle even at 400mhz. I am using a older antec basiq 350 watt psu maybe this is the reason for the high draw? I have one sys fan, ssd drive no other harddrive yet, or add in cards etc and a stock amd cooler with the fan on 50%. Idle temps get as low as 15c which is hard to believe but that is what coretemp says. Sorry to be longwinded but here are my main questions.
Here is a pic of my k10stat program to show how I currently have it set, advice on how to set it up better is welcome!
http://cl.ly/2c2l0N1h0r060k283X00
1. I can't find much info on k10stat, I need to know how to make the settings permanent and apply on boot. I know that it involves a command line setup but have not found a good guide on how to do it..
2. I notice when the computer is doing light tasks, that sometimes it jumps from 400 all the way to 2500 without stopping in the middle pstates. Why is this? Alot of times it will jump high and then settle back down to 800 or 1700 etc, but seems like I could mod the settings where it would not do this?
3. I see how to set the clock speed and volts, and the way it looks in my pic is stable on prime95, how does the up and down % alter things? What is the auto and unganged settings? and up and down ms?
4. Last, I have my bios set to s3 suspend, but cant get back up properly. It goes to full hibernate and shut off. When I pwr on, I get warning about possible wrong o/c setting? I go through bios and exit. No settings are changed & I know it is not a o/c prob. It will then boot and resume. I notice in the bios there is a setting to reset video upon suspend but I have tried both enabled and disabled so doesnt seem to matter. I have acpi version 3.0 enabled & set to wake on lan/pcie/pci etc. I'm assuming s3 is better than s1? I need to be able to go to standby and wake up with a keyboard or mouse input like a laptop otherwise I will not be wanting to leave it run alot etc.
Thanks in advance for any help!
