Just thought i would post my results on heatsinks,temps and case cooling.
Odin30
I did some testing on my alpha pal with sanyo denki fan. Normally i get temps around 30 degrees idle and 40 to 42 under load(games). But i have 1 120 mm fan and 1 80mm fan comin in. And 3 80 mm fans suckin out on top so my system temps are very low (18 to 19 degrees). I am usin a addtronics 7896.
Now what i wanted to test was the effect that system temps had instead of heatsink tests as many people seem to think that if they have a good heatsink they will get great temperatures for overclocking.
What i found by shutting off the 120mm in the front and 2 of the 80 mm in the back was that my system temp went up by 8 degrees and my cpu temp went up by over 10 degrees.
This is probably not only temperature involved but airflow in the case.
What i am trying to put across to alot of guys lookin for good heatsinks is that a good case(cooling) is just as important as any heatsink and most people seem to overlook that.
My tests were by no means scientific but do illustrate a good example as my room temp is always about 18 degrees celsius.
So go get some good case cooling before you expect some great results cause if you just read a review on a heatsink and expect those temps you could be sorely mistaken.
Hope this is not a post that has been done too many times before as it was just to clear up some new guys ideas on what to spend money on.
My 2 cents
Here here! That is a sweet setup Mike. Man, no wonder you really know your stuff. You're the man! 🙂
Nice case mikewarrior!!! I like the green and when you say case cooling you mean case cooling. How did you mount the card cooler fan (the angled one) screws or velcro? And my mobo is too big to do that anyway, plus I have a huge radiator (Aquacoil) in the front bottom of my case.
Hey Guys,
What's nice is, most of the time, I run my fans at 7V, so the noise is minimal 😀
Warcon,
The angled 92mm fan is attached with double-sided gel tape
Mike
