Just solved my floppy drive problem
superfly27
293
Well, since no one answered me, I figured maybe I should post the solution.
I flipped the cable and put it in the other way. How do you say that, upsidedown? It's a bad explanation but you know what I mean...;)
superfly27
293
LOL, I don't know. It may have been on another forum. But I swear I did not get a reply. That's OK. I just thought if someone does a search here for "floppy problem" they might find this thread.
That is such a relief. Now I'll be able to install drivers from it instead of that weird complicated crap you need to endure with Windows driver instalation. Well, I did learn however that you can do fdisk from the DVD drive and even within Windows by going to the C: prompt.
