thelittleprincess
I just received my new model 92P1102 ThinkPad T40/R50 Series 9 Cell Li-Ion Battery...
I've read up on batteryuniversity.com but am sooooo confused. Can someone explain to what I need to do in layman's term?
I know I need to charge up the battery. I've read that on some batteries, you need to charge and discharge 5 times before being able to maximize it and use it. But I don't think this is necessary for the Li-ion battery - am i right or wrong?
When it is charging, can I use my laptop still? Or should I charge overnight or for 24 hours with the laptop off?
I have the T40 (model 2379-D6U) and I do have Battery Maximiser installed - but because it's a T40, I can't set the charge minimum and maximum. I learned that it was the cycling that killed my former 6 cell battery of just under 1.5 years (almost 500 cycles!!!) So that way I see it, I will probably keep the battery charged up in my laptop and use the AC adapter while I am in school (8am to 3pm). When I do decide to use the battery - say when I not near an electrical outlet - how low should I allow my battery to go? I've read some as low as 3%, others say not to go below 10% and others also seem to day not below 80% - with the latter, that wouldn't get me much "mobile" ability would it?
At what point does the battery charging consider recharging as a full cycle? Sometimes i unplug the AC adpater to move from the main lecture room to the study rooms and then lose a few % in power - but when I plug it in again, and it charges, the cycle doesn' t increase if it was already near full. Am I making sense? From my understanding, I want to minimize the number of cycles in order to maximize my battery life.
Thank you so much to whoever can answer my questions (and those patient enough to have read this!!)
