M MikeMike Lifer Feb 6, 2000 45,885 66 91 Apr 26, 2003 #1 OK way to low of a score. could this be caused b/c i am running a few other programs? WD 120gb non se Maxto 80gb non se DMA mode 2 running, non raid. what other info? rig is in sig, (ultimate) umm ne help you could provide?
J John Moderator Emeritus<br>Elite Member Oct 9, 1999 33,944 4 81 Apr 26, 2003 #2 PCMark 2002 is useless in every way.
S Sid59 Lifer Sep 2, 2002 11,879 3 81 Apr 26, 2003 #3 ^ that and why are your drives on DMA Mode 2? I have 2 x maxtors on primary .. DMA MODE 5 Plextor Master DMA 2 WD Slave DMA 5 you might need a new cable.
V Viper96720 Diamond Member Jul 15, 2002 4,390 0 0 Apr 26, 2003 #4 Mode 2 is ATA-33 you need to be at mode 4 or 5 should about double the score.
MichaelD Lifer Jan 16, 2001 31,528 3 76 Apr 26, 2003 #5 I only score 989 in PCMark 2002. I have a 80GB WDSE drive. It's set at Ultra DMA mode. (5) What gives here? Could it be that I have a LiteON DVD Rom on the same IDE channel? It's set at Ultra DMA as well.
