- Jan 30, 2001
- 2,060
- 0
- 76
I just picked up a rebaged Cendyne (liteon) 52x and the drive is amazing! But I'm having an annoying issue.
I bought some good quality TDK 48x certified cd-rs to go with the drive, and the safe disc picks them up as being 52x, woohoo I think. Well, I burn (through nero, or the built in cd burning in winXP) a selection of mp3s in audio cd format the way I always did before with my old burner, it burns, and it works in my computer. I put it into my car cd player, and it works as well, except that randomly it gives me a 'E20' error (can not focus correctly error.
I bring the cds in (I did multiple ones), and throw it through nero to do a cd quality check, and it gives me a perfectly straight green line showing the data burned flawlessly and the disc is perfect (I tested it in 3 different cd-roms with this test). I burn the next cd at 16x, and that one works perfectly in my car, on the same media. I check cd speed again and again it says it's burned exactly as correct at the first disc.
I've tried firmware updates and that didn't help either. Any ideas? I suppose I can just burn slower, but dang it, if the discs are supposedly perfect then whats the problem?
