So, I wanted to learn how to do my brakes, because I'm rough on them. My uncle, who's been a mechanic for 50 years, who's visiting from California, offered to show me how.
I can't believe it's so easy.
Pop off tire
Compress brake cylinder
remove caliper
remove rotor clip
exchange rotor
swap out pads, put on new pads with grease and clips
put rotor clip and caliper back on
put wheel back on
pump brakes.
I've never done it before, and it tok me literally an hour to do, and 170 bucks in parts. Instead of 350+ to do it from a shop.
Pop off tire
remove caliper
remove rotor clip
exchange rotor
put wheel back on
pump brakes.
