Just got last of my parts... nervous....
Xesh
187
I'm really nervous about putting the HSF on the CPU... it just seems so delicate. Can anybody tell me how to avoid killing my processor? :eek:
andalas
505
Don't be nervous :) and go check amd website for a guide how to put HSF on the CPU.
wfbberzerker
10,423
when you put on the hsf, hook the side WITHOUT the ridge sticking up first. then push down the side with the ridge, using a flathead screwdriver. you have to push down REALLY hard. if it looks like it doesnt go out far enough (if it cant hook over other clip-dealie), then you should push out a little bit with the screwdriver too. just dont let the screwdriver slip out and break teh mobo!
AvidOC
Banned
Apr 10, 2001
669
Dont sweat it, i was exactly the same, just take deep breaths and.....:D no seroiusly, take your time, mount the heatsink so its flat on the Die and press on the CLIP not the heatsink, i found myself doing that once
Good Luck :D
EDIT: yes do what gopunk said, i did it, just be careful not to do it too much
crypticlogin
4,047
Uh, unless I missed something, putting on the HSF on the CPU is dependent on the specific CPU socket and HSF. Definitely find a site specific to your setup.
