MaDfLaMe37
Alright, first problem...
The mic's not working? I try it in sound recorder and in ventrilo and there's nothin'... No matter if I put it in the front I/O ports or in the back. The sound works fine in both places--just not the mic.
What could be the problem? I'm pretty sure I have the mic stuff inside all connected correctly...
Second problem:
There's a little icon down on the taskbar and it's one of those "Safely Remove Hardware" icons... When I double-click it, it brings up the window and my hard drive is listed as the hardware to uninstall... Why is that? Did I do something wrong... Or how do I remove that icon so someone doesn't just come up and remove my harddrive??
Second problem:
