Originally posted by: Zambien
SO i freaked when I saw Anand's article on the new 90nm technology. Not sure if I had too good of a reason to or not... you decide.
Here's my new System...
AMD Athlon 64 3000+ socket 939
MSI neo2 platinum (nforce3 ultra) mobo
2x512 ocz platinum rev 2
(noticing a pattern yet?)
Thermaltake silentcool k8 cooler (same one from anand article)
seagate 160gb sata 7200 rpm drive.
I was able to get close to Anand's settings running stable...
3000+ running @2520 mhz
280 mhz FSB
2.5 4 4 10 1T memory timings
CPU voltage running at 1.472
memory voltage at 1.75
I tried taking the voltages and FSB higher and while it would run and I could get through 3dmark03 ok, it wasn't stable.
I am running an Antec 300w (from the old computer) power supply with a 6800 vanilla... maybe this is why I can't hit Anand's numbers? Either way it's much faster than my old 2000+ thoroughbred that I could only get an 8% overclock out of!! =) So I'm pretty happy. Thoughts anyone? Did I make a huge blunder with this purchase?
Thanks!
Zambien
Well, I ended up going with an Enermax 460W whisper II. It has +12v@33A if I'm remembering correctly...
Oh yeah, about those CPU temps. I throttled back the o/c to 260 mhz fsb so the CPU is running a little above 2.3ghz. I'm going to bump it back up when my power supply arrives tomorrow.
Anyway, at 2.3 ghz it never went above 42 C. This was while running 3dmark03. I'll start another thread once I get my PSU and am planning to include max CPU o/c, max FSB o/c, and max memory o/c.
Thanks for everyones help and advice!
Adam
Hey, you're welcome. Glad to help!
As far as HT calc goes, go to the page below and do a search for HT freq.
http://www.msi.com.tw/program/.../news_page.php?UID=337
The resetting i just messed with it till I got it to work. Just an FYI, if you do a jumper level restore to the bios, you'll have to do this reset again.
Once you get your max o/c will you post it up here? I'm curious to see how close our chips are once I get my PSU.
Cya,
Adam
Originally posted by: duffin
thomas-
The DRAM timings I have to select from are AUTO,100,133,166,200. I'll check out the a64 tweaker tool. Thanks for the advice.
acivick-
I'll move my SATA drives to ports 3 and 4 and let you know how it goes. Now that you mention it I remember reading that somewhere.
Just as a side note, I ran memtest with my oc'd memory timings and all went well... I sure hope it's the hard drives holding me back. Thanks all.
To be continued.
