I took the power supply out of an old IBM computer. It doesnt have the standard "ATX" power plugs. I believe the style of the power connectors on it are called "P6", but the actual connectors themselves say "P1" and "P2". I'm trying to use this power supply to run 2 fans and a water pump. I tried just plugging it into the wall, but it didn't respond. I'm think I need to "jump start" it to get it going. On a standard ATX connector, you would connect the green and black wire, correct? What wires do you connect on this power supply to start it? The "P1" connector has: black, black, blue, yellow, red, and orange. The "P2" connector has red, red, red, white, black, black.
