Jump start = lose power steering?
Kaido
Feb 14, 2004
51,970
7,416
Long story short, wife stopped to help jump start a lady in my 05 Saturn, now the power steering won't work. Getting it towed now, any idea why that happened? It's a leased car and is taken in just about every month for maintenance, so it should be in top-notch shape.
Black88GTA
3,430
Power steering is a hydraulic system, the jump start should not affect it. Did you check the serpentine belt? A broken / missing serp belt would cause loss of power steering.
Minjin
2,208
Jumper cables got intertwined in the belt(s) and threw the power steering (probably serpentine) belt? On many cars, loss of power steering means loss of water pump too. So be glad she didn't try to drive it home.
AMDMaddness
2,406
Power steering uses no actual DC power, it has a pump driven by the engine and a hydraulic driven power assist motor. I will take a wild guess and say one of your belts is broken.
Pete
Mark R
16
While some cars do have electric power steering, I don't think the Saturn is one. In the usual case the power steering pump is powered directly from the engine by a drive belt.
Most likely it's a coincidental fault - either a damaged drive belt or malfunctioning power-steering pump.
AnonymouseUser
9,943
107
The Saturn Vue definitely has electric power steering, so it is possible something got fried. Most likely just a fuse/fusible link, though.
Kaido
Feb 14, 2004
51,970
7,416
Belt is good, but it looks like it does have Electric Power Assist.
JMWarren
1,201
Most Saturns have electric power steering. ION and VUE do atleast. Check the fuse, it's probably a Maxi Fuse, likely under the hood.
Pepsi90919
did you check to make sure saturns don't have electric power steering?
BabaBooey
10,476
What I was thinking also...;)
Black88GTA
3,430
Well excuse me, I guess not. And apparently, neither did the 3 other people who posted after me pretty much saying the exact same thing. :roll: And please, show me where I said that was definitely the cause? I only suggested looking at the belt since it is the easiest thing to check, and someone with zero car knowledge would be able to easily tell if that was the cause of the problem.
But your comment was very helpful though, great contribution to the thread! :thumbsup:
