jswdk-1.0.1 under Window problem
larva
185
Hi,
I have installed jswdk-1.0.1 under Window and I put my java class files under d:\jswdk-1.0.1\webpages\WEB-INF\servlets. Whenever I recompile my java code, I need to restart the jswdk thenit will take effect. If I don't restart it, no matter how many times I refresh my browser(IE6), I won't work. I can I make it to take effect without restarting jswdk ? Thanks !
regards,
Larva
michaelh20
482
I am not sure of the particulars of the software you're using, but Servlets only "refresh" every so often (like a minute or two or something on that order, not sure if you can reconfigure it) and they do *not* just refresh because you recompiled the code. So either you wait a while, or restart it I guess. Perhaps you can reconfigure it?
manly
13,341
4,102
That's an ancient servlet container; it won't do hot reloading of classes. Apache/Jakarta Tomcat 4 might. All containers will refresh JSP pages without restarting the server. Some will handle servlet (and other) classes as well.
Personally, I'd recommend evaluating Caucho Resin.
larva
185
Hi,
My code are below:
public void init() throws ServletException
try
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver");
String url = "jdbc:eek:dbc:tweb";
dbCon = DriverManager.getConnection(url,"larva","larva");
catch(ClassNotFoundException e)
System.out.println("DB Driver not found");
System.out.println(e.toString());
throw new UnavailableException(this,"Database driver class not found");
catch(SQLException e)
System.out.println("Error connecting to DB");
throw new UnavailableException(this,"Can't connect to DB");
public void doPost(HttpServletRequest req, HttpServletResponse res)
throws ServletException, IOException
ResultSet rs;
Statement stmt;
StringBuffer qry = new StringBuffer(1024);
int numCriteria = 0;
String r1;
res.setContentType("text/html");
PrintWriter out = res.getWriter();
String user = req.getParameter("txt_username");
qry.append("SELECT * FROM USERS WHERE NAME = '");
qry.append(user);
qry.append("'");
try
stmt = dbCon.createStatement();
rs = stmt.executeQuery(qry.toString());
r1 = rs.getString("LOGON_PASSWORD");
res.sendError(res.SC_ACCEPTED, qry.toString());
return;
I m connecting to my local Oracle8i DB. I got I following error message:
message : SELECT * FROM USERS WHERE NAME = 'larva'
description :This request was accepted for processing, but has not been completed (SELECT * FROM USERS WHERE NAME = 'larva').
There isn't any for connecting to DB but when executing a query, I receive this stupid message. Please help, Thanks !
regards,
Larva
