JS "onchange" does not seem to work...
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Code:
//These are two checkboxes for a form.
<input type="checkbox" id="spw" name="spw" value="Single Property Website"  amount="25" onchange="sum_amount()" checked />
<label for="spw"> Single Property Website: $25<br></label>
<input type="checkbox" id="panoramas" name="panoramas" value="Panoramas / Virtual Tour Effect" amount="20" onchange="sum_amount(); return checkbox();" >
<label for="panoramas">Panoramas: $20<br></label>
//If the Panoramas checkbox gets checked, the SPW checkbox automatically gets checkmarked as well.
function checkbox()
		if(document.getElementById("panoramas").checked==true)
			document.getElementById("spw").checked=true;
//If the SPW checkbox is checked, the total_sum is 25.
//If Panoramas is checked, total_sum is 20.
//If both are checked, total_sum is 45.
function sum_amount()
var total_sum=0;
if(document.getElementById("spw").checked==true)
				total_sum+=25;
				total_sum+=20;
The problem here is with total_sum and onchange and checkbox()
With both SPW and Panoramas checkmarked, the total_sum should be 45.
If I manually checkmark SPW, total_sum is 25
If I then checkmark Panoramas, total_sum is 45.
BUT IF..
Both boxes start off unchecked.
I checkmark Panoramas.
The checkbox() function will then automatically checkmark SPW.
So now both boxes are checked.
But the total_sum is 20, not 45.
If I toggle the SPW checkbox off and then back on, total_sum changes to the correct amount of 45.
Why is it that when I use the checkbox() function to automatically checkmark SPW, the onchange event does not work and total_sum is not correct?
First using inline javascript, meaning stuff like onchange="myFunction()" is bad practice and doing this in 2014 means you will need to refresh your knowledge.
http://stackoverflow.com/questions/5871640/why-is-using-onclick-in-html-a-bad-practice
The issue is very obvious. look at the order the functions are executed. If you don't get it with this hint, I suggest you search for a different career path.
You really couldn't try to get your point across with insulting him?
Try harder next time.
esquared
Anandtech Forum Director
I can't find a problem (other than what beginner99 has said which is that this is very much the old style of JS).
The following example works exactly as its meant to - when panorama's is clicked SPW also gains a check mark if it doesn't have one. The functions get called in the debugger.
Here is the full example I made from your code, just save it as a html file:
Code:
<html>
<head>
<title>ATF problem</title>
</head>
<body>
<script>
function checkbox()
var total_sum=0;
				total_sum+=25;
				total_sum+=20;
</script>
</body>
</html>
Although I agree with the point about unobtrusive JavaScript, that was a pretty rude response. The OP understands the order that the functions are being called; his/her question was:
The answer is that the browser knows when an event is triggered by JavaScript (as opposed to being triggered by the user clicking on a control, for example), and it is ignoring it. Google "triggering JavaScript events manually" and you will get an idea of how to accomplish what you are trying to do.
