Jigsaw blade for cutting side panels?
jspeicher
1,904
I started cutting today into my side panel for a window. I dremeled a slot for my jigsaw to start in, but the blade isn't as fine as I thought.
What blades do you guys use? How many teeth? The case I need to cut into an older gateway panel and its a little stiffer and thicker than todays panels.
mechBgon
Oct 31, 1999
30,699
Look for bimetal blades designated for cutting sheet metal.
Mday
18,647
bimetal and 24tpi or higher (but not too high), i finally managed to find some locally that had 36 =). dont forget to use cutting lube.
Dan
I used bi-metal, 24-tpi to cut into those old Enlights. Be sure you wear safety glasses.
