Hi people, don't post here much but wanted to show off my first case mod to some appreciating people. I'm doing a case mod on my computer of 1.5 years. Since I started working at a computer repair shop I have been thinking about working on my own computer much more than I used to. So I had the case open thinking about possibilities while it was running and I decided to touch the spinning CPU fan, well a blade broke off and I had to turn off the computer and put in a new fan which I picked up from the shop I work at from a box of CPU fans(free). (I just can't stop myself from touching moving objects ;-) )This gave me incentive to go ahead and clean up the cables and wires. it had previously looked like this:
http://152.10.254.214/box/case_mod/DSC01940_800x600.JPG
I also moved the hard drives to a lower location where I could put a fan on them, I measured their temp at 45 C (113 F) before so I thought a fan would be a good idea. They are two 80 GB maxtors if anyone is interested. This is what it looks like after the clean up and rearranging:
http://152.10.254.214/box/case_mod/dsc04035_800x600.jpg
After I got it all cleaned up and such I was thinking, it would be a shame to close it up with out anyone being able to see the inside like it had been. So I decided I needed a window, and here is the result of some jig saw hackery, I made the straight lines of the outline with a 30 CM (12 inch) ruler and the curves with a frisbee and a plastic cup:
http://152.10.254.214/box/case_mod/dsc04041_800x600.jpg
Sanded and ready to paint:
http://152.10.254.214/box/case_mod/dsc04044_800x600.jpg
http://152.10.254.214/box/case_mod/dsc04047_800x600.jpg
The scrap sheet of acrylic I picked up at Lowes home improvement for $3 USD
http://152.10.254.214/box/case_mod/dsc04048_800x600.jpg
Not the prettiest paint job ever done, but the window looks nice. Now I need to add light. This was my first mod ever, and first time painting w/ spray paint like this in a long time... so while it's not professional looking it is decent:
http://152.10.254.214/box/case_mod/dsc04051_800x600.jpg
http://152.10.254.214/box/case_mod/dsc04054_800x600..jpg
I didn't see a way to post images.. so this is what I've done. If there is a way to do it, I'll add image tags later.
