Well, when the description says 0.6 mm chasis thickness that tells me that it really isn't that good. Great if you are going to chop it up for case mods, but I wouldn't pick it up. Think about taking off the side panel and you bump into it and it bends all up(Has happened). Case ruined.
I had a 0.6mm thick case from Codogen and I was working inside the case. Leaned the side panel against the wall and when I was working I accidentally kicked the side panel(not hard) and man it was messed up, big crease down the middle of the panel. Compare that to the Antec's that you can't bend or mess up with a sledge hammer.
