Javabat practice problem help
Shadow Conception
1,539
It's this.
Thus far, the code I've written is the following:
public int caughtSpeeding(int speed, boolean isBirthday)
if(speed <=60 || (speed <= 65 && isBirthday))
return 0;
if(speed >=61 && speed <=80 || (speed >= 66 && speed <= 86 && isBirthday))
return 1;
if(speed >= 81 || (speed >= 86 && isBirthday))
return 2;
However, I get the following error code after it refuses to compile: This method must return a result of type int.
I don't understand why it doesn't work. I'm returning integers ("return 0, return 1, return 2). Can anyone point me in the right direction?
mundane
5,603
8
The compiler wants you to put a return at the end of your function - it can't evaluate whether you've analyzed every possible case within your conditional statements.
Alternatively, you might want to use if, else if, else statements instead of your sequence of independent ifs.
Shadow Conception
1,539
Thanks a bunch! I made it follow an if-elseif-elseif pattern, as you suggested. At the very end of the code, I also added an "else return 3;", and Javabat indicates it's correct.
LumbergTech
3,622
another alternative ..if you are sure that at least one of the cases will be true, is just to return the final case without checking
in this example...just return 2 if all of the other conditions fail
the ///else if part is just commenting it out for documentation purposes
return 0;
}else if(speed >=61 && speed <=80 || (speed >= 66 && speed <= 86 && isBirthday))
return 1;
//else if(speed >= 81 || (speed >= 86 && isBirthday))
return 2;
