Java Question (On abstract classes) (Problem solved)
Joony
7,654
Ok, so I'm playing with this new concept of "abstract". I made a very simple program that dosen't do much. I have run across an issue, I get a error message when I compile. "cannot resolve symbol" variable c in class french.
public class Test
public static void main(String args[])
System.out.println("bah");
Donut yum = new French(5);
yum.EatDonut();
public abstract class Donut
int cost;
public Donut(int c)
cost = c;
public abstract void EatDonut();
public class French extends Donut
public French(int c)
super(c);
public void EatDonut()
System.out.println("I am eating a French Donut at the cost of" + c);
notfred
38,241
4
You should be using "cost" not "c". cost is the instance variable, the scope of "c" is only the constructor.
Ameesh
23,686
you havent decalred a variable called c,
System.out.println("I am eating a French Donut at the cost of" + c); <----- no var named c here in scope
notfred
38,241
4
I edited my earlier post, but I'll say it again since a lot of time people don't re-read psots they already read:
Edit: I see I should go back and read things as this has already been solved.
BigJ
21,330
System.out.println("I am eating a French Donut at the cost of" + cost);
Look at whats bold
Also, might want to put in "cost of " + cost + " dollars"); You know, just for aesthetic purposes.
FeathersMcGraw
4,041
first make cost public or protected and then change c to cost
Changing the visibility of cost isn't necessary since all of the classes are in the same package. But I'd make it protected just out of principle.
Joony
7,654
hmm, wow, it worked even without making cost protected...
so by "supering" c in French, it already knows cost from donut?
notfred
38,241
4
super(c) in French just calls the Donut constructor with c as an argument.
