java question (compilation problem)
notfred
I have this line of code:
long start = Calendar.getTimeInMillis();
the class imports java.util.* which includes the Calendar class.
When I try to compile it, I get the error:
"non-static method getTimeInMillis() cannot be referenced from a static context"
WTF? Nothing I have declared is static... why is it doing this?
getTimeInMillis() is not a static method, which means you can't use Calendar.getTimeInMillis(). You have to instantiate a Calendar object and call it from there.
Yep. You need to do:
Calendar myCal = new Calendar();
long start = myCal.getTimeInMillis();
Yeah... I jsut figured it out... and i tried it, and now it bitches about getTimeInMillis being protected. How the hell to I access a protected method of a class I didn't write?
