Java problem: Don't know how to compile with the sdk
import java.net.*;
import java.io.*;
public class IPFinder
public static void main(string[] args) throws IOException
String host;
BufferedReader input =
new BufferedReader( new InputStreamReader(System.in));
System.out.println("\nEnter host name: ");
host = input.readLine();
try
InetAddress address=
InetAddress.getByName(host);
System.out.pringln("IP Address: " + address);
catch (UnknownHostException e)
System.out.println("Could not find " + host);
java -classpath TCPServer.java runs with no problem
java TCPServer replies
"Exception in thread "main" java.lang.NoClassDefFoundError: TCPServer
I am sure I'm compiling this wrong... I have the j2sdk-1_3_1_15-windows-i586.exe installed and I'm just copying off of handouts... can someone tell me what I'm doing wrong?
1) "java -classpath TCPServer.java" should produce an error.
2) The "java" command runs compiled .class class files
The "javac" command compiles java .java source files.
3) Where is the TCPServer.java / .class file? You showed us the source for another class, IPFinder.
I dunno what I'm doing.... I just need to get the file above, running, hell or high water in a command window by 7:00...... I know nothing about java... could you guys please just tell me what to do 😉 ?
If you don't know anything about java, why are you responsible for working with java source files?
Originally posted by: znaps
Type "javac IPFinder.java" and see if that creates a IPFinder.class file in the same directory.
negative, even with the file named IPFinder.java.
good question, ask my prof. He wants this by 7
Working from memory - try
javac TCPServer.java, when you're in the same directory as the file. You may need to edit your PATH for access to the javac binary. Or
c:\jdk1.3.1_15\bin\javac path\to\your\file\TCPServer.java
and tell us the error.
type "javac IPFinder.java" and see if that creates a IPFinder.class file in the same directory.
type it exactly as I said, not "javah..", not "javac -classpath" and not "java ..."
Then type "dir" and see if there is an "IPFinder.class" file.
If there is, type "java IPFinder"
Are you sure the name of the file and the name of the class are the same? As in, for the class IPFinder you should have a file called IPFinder.java.
Also, time to dump the way old jdk. It's two major versions old 😛
HOORAYYYY THE DAY IS SAVED!!!!
