- Feb 4, 2003
- 3,370
- 0
- 71
I have set up a tomcat server with SSL running in a vmware on my machine using a self signed certificate. I can connect to this no problem with a browser from my main machine with the url https://myserver:8443.
However, I am not able to connect with a Java client. I always get the below exception. I read that I need to add it as a trusted certificate in the keystore. I went to the site with firefox and saved the certificate as a .cer file, and imported it into the default keystore at c:\users\louis\.keystore. I still have the same problem. I think the problem is the client is not using the keystore, and I don't know how to make it do so. I tried adding the following argument to the run command:
-Djavax.net.ssl.trustStore=c:\users\louis\.keystore -Djavax.net.ssl.trustStorePassword=changeit
but it doesn't help.
Here is the exception I'm getting:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Alerts.java:174)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1611)
at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Handshaker.java:187)
at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Handshaker.java:181)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1035)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:124)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshaker.java:516)
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Handshaker.java:454)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:884)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1112)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1139)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1123)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:434)
at sun.net.www.protocol.https.AbstractDelegate...t(AbstractDelegateHttpsURLConnection.java:166)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1049)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:234)
at Test.main(Test.java:39)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:285)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:191)
at sun.security.validator.Validator.validate(Validator.java:218)
at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:126)
at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:209)
at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:249)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1014)
... 12 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:174)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:238)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:280)
... 18 more
... 12 more
... 18 more
