Java Optional method arguments/default values
jonmullen
2,517
How do I define and argument in a method as optional, that way if it is not supplied it is ok. In php it would be something like this
function($required,$optional="option")
print $required;
if($optional != "option")
print $optional;
Mitzi
3,775
How about:
Class myClass(paramType paramName) {
if (paramName == null) { blah }
Call method with: myClass(null);
I'll go try it out now...
Mitzi
3,775
public class test {
public static void main(String[] args) {
// String myString = "hello";
String myString = null;
myMethod(myString);
static void myMethod (String myParam) {
if (myParam == null) { myParam = "default"; }
System.out.println("myParam: " + myParam);
Try that. Note that you still need to pass a parameter to the method but it is acceptable to simply pass null (i.e. myMethod(null);).
There may be a way to specifically identify that a parameter is optional but I'm not aware of it, sorry.
Kilrsat
1,072
The nice way to do it is to have two methods:
static void myMethod() {
//just calls the other version of the method, with null values
myMethod(null);
static void myMethod(String test) {
//actually does stuff
AmigaMan
3,644
myMethod(null);
what he/she said.
