Java: How to check if a double has a decimal potion?
statik213
I'm doing this right now:
double d;
if(d > (long) d)
// has a decimal potion
else
// is an integer
is there a better a way?
I would have done this:
double d;
if((int)d == d){
//stuff
else{
//other stuff
Your code doesn't work with negative numbers.
You can use modulus operator (%) with doubles as well.
double d;
if (d % 1.0 > 0)
// We have decimal part.
double d;
if((int)d == d){
//stuff
else{
//other stuff
ok, didnt think of that
