Java Homework Help - Defining and using primitive arrays
Arik5405
2,044
So I submitted my lab and the professor sent it back. His comments have me confused. My submission and his comments are in the 2nd post. Any help would be greatly appreciated.
Here is the original lab requirements:
Lab 21
1. This program "bombs" at runtime. It's SUPPOSED to use a for loop to display the values of its array elements in reverse order as follows:
u
o
i
e
a
See if you can fix it.
Code:
public class Lab21A {
  public static void main(String[] args) {
    char[] vowels = {'a', 'e', 'i', 'o', 'u'};
    for (int i = 5; i >= 1; i--)
      System.out.println(vowels[i]);
2. See if you can fill-in the blanks to make this program assign a value of 1 to the first array element, 2 to the second array element, etc.. NOTE: Your code must be able to handle an array of ANY size so be sure to test your answer with an array having a different number of elements to see if it still works.
Code:
public class Lab21B {
    int[] values = new int[10];
    for (int i = 0; _______________; i++) {
      _____________ = _________;
      System.out.println("Element " + i + " = " + values[i]);
3. See if you can supply the missing code to make this program "swap" the values of the first and last array elements. If done correctly, the program's output will be as follows:
d
b
c
a
NOTE: Be flexible in your code so that it can handle an array of ANY size, not just a four element array.
Code:
public class Lab21C {
    char[] table = {'a', 'b', 'c', 'd'};
    // YOUR CODE GOES HERE
    for (int i = 0; i < table.length; i++) {
      System.out.println(table[i]);
Arik5405
2,044
My Submission:
Lab21A
Code:
    for (int i = 4; i >= 0; i--)
Lab21B
Code:
    for (int i = 0; i < values.length; i++) {
      values[i] = ((i) + 1);
Lab21C
Code:
    char temp = table[0];
    table[0] = table[3];
    table[3] = temp;
Professor's Comments:
Prof said:
"in c you can't hard code things
in a table x
x[0] is the first
x[x.length-1] is the last
you must save one first before swaping"
Prof said:
"You still need to fix c or you will get a lower grade"
Arik said:
"I am kind of confused about what to do. You first commented:
in a table x
x[0] is the first
Did you mean I have to fix something with A? Is C ok?
Thanks for your time.
-Arik"
Prof said:
"instead of using the word table I use x for the table name? Does this help?"
tatteredpotato
3,934
Your solution for 'c' isn't flexible enough to work for any size array, which is what he doesn't like. He pretty much gave you the solution though.
Arik5405
2,044
ok, did you find anything wrong with A? from his comments it made me kind of think there was something wrong with both A and C....
I'm pretty sure there is nothing wrong with Lab21A, I think he meant (in "a table x") and not ("in A", table x) (as if referring to Lab21A).
Arik5405
2,044
How about this? Is this worthy of resubmission? It compiles and does what it's suppose to....
Code:
    char x = table[0];
    table[0] = table[table.length - 1];
    table[table.length - 1] = x;
Schmide
5,798
1,126
Why not have your loop execute like so?
Code:
    for (int i = values.length-1; i>=0 ; i--)
Arik5405
2,044
Code:
If you are referring to B, it's because we are suppose to only fill in the blanks and not change anything else.....
