Java help.
mikysee
How do I test to see if there is something in a string?
If I typed in the console:
java Test hello
There is a string.
And if I typed:
java Test
There is no string.
I got the first part but I keep getting an error when I try the second one.
Thanks for any help.
You can use:
the .length() function of String.
You have to differentiate between a String object that you have access to and one that you do not.
In your example, you'd have a mian that looks like this:
static public void main(String[] args) {
You must check that args.length isn't 0 to know if a string was passed as a parameter to the program. After that you can check args[0].length() (though you shouldn't have to. As far as I know no empty strings can be passed in from the command line).
You have to get access to the string first from the array args: String[] args
After which you test whether there is a string inside the array or not.
java Test hello
There is a string.
And if I typed:
java Test
There is no string.
Assuming the string in question is the only parameter then:
public static void main (String[] argv) {
if (argv[0] != null && argv[0].length != 0 && !argv[0].equals("")) {
// You have a valid string
} else {
// You do not have a valid string.
Originally posted by: m0ti
You can use:
class NullParam {
public static void main(String[] args) {
for (int i = 0; i < args.length; i++) {
System.out.println(args[ i ]);
manly@p3-800:~/java-dev> javac -g NullParam.java
manly@p3-800:~/java-dev> java NullParam "" abcde
abcde
