Java help request
Geez, I hate this self-teaching book. Can someone show me how to do the following problems in Java and also recommend a good self-teaching book that actually explains the concepts with a lot of examples. Thx.
1. The population of Mexico in 1990 as 89.2 million. Write a program that calculates and prints out the year in which the population of Mexico will reach 120 million, assuming a constant growth rate of 2.3% per year. Use a While loop to accomplish this task.
2. Write a program with a method int addOdds(int n) that calculates and returns the sum of all odd integers from 1 to n. Your method should use exactly one ?for? loop and no other iterative statements. (Do not use the formula for the sum of odd numbers).
import java.io.*;
public class PopulationApp{
...public static void main(String[] args){
......float fPopulation = 89200000;
......int numYears = 0, year = 1990;
......while (fPopulation < 120000000){
.........fPopulation *= 1.023;
.........numYears++;
......year += numYears;
......System.out.println("Mexico will reach 120 million people in " + year);
public class AddOdds{
...public int addOdds(int n){
......int i, sum = 0;
......for (i = 1; i <= n; i = i + 2){
.........sum += i;
......return sum;
I think I may have picked a book that is designed for people with a bit of background in Java programming. Are Sun?s tutorials good for complete newbies.
WOW! It only took you like a couple minutes to figure out the answer and I was working on those problems for nearly four hours before I gave up.
Thank you very much, sir.
Yes, the Sun tutorials are pretty basic. They may assume that you have some knowledge about basic programming in general, but no prior Java-specific knowledge is assumed.
