Java help for newb
WdnUlik2no
169
Hello,
I need a little help in java namely regarding the JTextField. Is there anyway to get the text from the field and compare it to another string? No matter what I do the result is always false. I even initialized the value of the JTextField to "", but when I compare it to a string that also equals "", the result is still false. Please see example:
import java.awt.event.*;
import javax.swing.*;
public class CListener implements ActionListener
private JTextField textField;
boolean dec = false;
boolean first = false;
private String op;
double num1, num2, result;
//Constructor
public CListener(JTextField t)
textField = t;
textField.setText("");
System.out.println(textField.equals(""));
op = "";
num1 = num2 = result = 0.0;
Output after I create new CListener:
C:\JAVAFI~2\Chapter13>java CListener
false
Why isn't this value true if textField.getText() = ""? Please help.
Thyme
2,330
Use getText()
You're comparing a String to a JTextField and which is comparable as Object to Object. Such comparisons are based on the address which of course will always be different.
WdnUlik2no
169
public CalculatorListener(JTextField t)
textField = t;
System.out.println(textField.getText() == "");
op = "";
OK, I tried this on line 5:
textField.getText() == "";
and I still get the same result:
false
Thyme
2,330
println(textField.getText());
println(op);
And see if that aids in debugging.
Kilrsat
1,072
You need to use .equals comparisons for strings.
So:
textField.getText().equals("") is the check you want, not textField.getText() == ""
SinNisTeR
3,570
So:
winnar
