Java Again.. Well not really... Maybe a little :)
Krueger81
each worker receives 5% raise each year.
lets say I type in 20000 for starting salary and the dude is age 65 how would I computer that each year
here is the code I have so far and it gives me 21000 as the asnwer. I know my math is not right somewhere
WHOLE CODE:
import java.io.*;
public class problem6
public static void main(String[] args)
throws java.io.IOException
double age, lcv, startsalary, endsalary = 0;
String s1, s2, s3;
InputStreamReader isr = new InputStreamReader(System.in);
BufferedReader br = new BufferedReader(isr);
System.out.println ("Please enter your name:");
s1 = br.readLine().toUpperCase();
System.out.println ("Please enter your age:");
s2 = br.readLine();
age = Double.parseDouble(s2);
System.out.println ("Please enter your starting salary:");
s3 = br.readLine();
startsalary = Double.parseDouble(s3);
for (lcv = 0; lcv <= 65; lcv++)
endsalary = (startsalary *= 1.05);
System.out.println (age + "\t" +s1+ "\t" +startsalary);
System.out.println (endsalary);
for (lcv = 0; lcv <= age; lcv++)
startsalary = startsalary + (startsalary *.05);
well that got me closer
but doesn't it have to be yr 1+5% +y2 +5% and then you ad those together till you get to the year that you have typed in?
Well in VB it's this:
function whatever(PayStart as long, Years as long)
for i=1 to Years
PayStart = PayStart * 1.05
next i
end function
So in java it should be this
what am I missing?
this should work too
startsalary = (startsalary *1.05);
Doesn't this work:
import java.io.*;
String s1, s2, s3;
s2 = br.readLine();
s3 = br.readLine();
startsalary = (startsalary * 1.05);
System.out.println (startsalary);
for i=1 to Years
next i
end function
what am I missing?
that gives me an answer of 21000
You were outputting the endsalery, not the startsalery. I changed the code. Try my edit.
here is the actual problem maybe that will help.
" Write a program to estimate how much a young worker will make before retiring at age 65. Request the worker?s name, age, and starting salary as input. Assume the worker receives a 5 percent raise each year. For example, if the user enters Helen, 25, and 20000, then the following should be displayed on your screen:
Helen will earn about $2415995."
Phil
Did you try my edit?
import java.io.*;
String s1, s2, s3;
s2 = br.readLine();
s3 = br.readLine();
I am just assuming it would work really. *shrug*
Phil
You need a variable that keeps track of earnings.
Add the startsalary to earnings, then multiply startsalary by 1.05.
Phil
for (lcv = age; lcv <= 65; lcv++)
earnings = salary + (salary * .05);
salary = earnings + (salary + (salary * .05));
System.out.println (age + "\t" +s1+ "\t" +salary);
System.out.println (earnings);
will this do???
ok this is confusing.
should it not be:
yr1 + 5% = end
end +yr2 +5% =end2 and so on
quote me if I am wrong.
Math would be like this.
Year 1 = 20000
Year 2 = 20000 * 1.05 (or 21000)
year 3 = 21000 * 1.05 (or 22050)
Year 4 = 22050 * 1.05 (or 23152.5)
Year 5 = 23152.5 * 1.05 (or 24310.125)
etc.
So the math is correct.
Your code probelm is with this:
If that is in a loop, you are continualy setting endsalary to startsalary *= 1.05
You need to add the endsalary again, or you will always get 21000.
Put a printout in the loop, and you will see what I mean.
yours will output
21000210002100021000210002100021000...
when the rigth answer would be
210002205023152.524310.125...
Phil
will this do???
No. Think about it outside of the context of code.
Helen starts working at the age of 25 at $20,000 a year. Her total earnings are $20,000 after the first year. She then gets a 5% raise. to $21,000.
After the second year, her total earnings are now $41,000. She gets a 5% raise, and now her salary is $22,050.
After the third year, her total earnings are now $63,050. She gets a 5% raise, and now her salary is $23,152.50.
Now look at your code and tell me why it's wrong.
Originally posted by: tfinch2
What level are you? Freshman in college? Quit programming.
thank you for the kind words.. now go fvck off
for all the others thank you very much for the help
If you had used Scanner instead of BufferedReader, i could have helped, but I have never learned buffereedreader, I just use Scanner.
His usage of Scanner or BufferedReader is irrelevant to his problems with the code.
