iamwiz82
- Jan 10, 2001
- 30,772
- 13
- 81
Originally posted by: DivideBYZero
Originally posted by: everydae
Well, first of all, if you think Korean tranny is good, think again. Most of Kia/Hyundai's cars in US use Aisin (= Toyota) tranny. In Korean market, they use their own tranny for their cars, and failure rate is nowhere closer to US cars. They barely lasts 7 years unless you gave a really serious and good care. (ie, only driving under 3000RPM, frequent mission oil change, etc) Korean calls it yoo-ri mission, by yoo-ri means glass. (Easy to be broken anytime)
Genesis' tranny is ZF, because they have no idea how to make RWD tranny with capable of 250+ HP.
Engine, on the other hand, is really getting better every year. It's still more to go, especially in the area of variable timing technology and durability. But at least it's not a light year difference from German/Japanese engine.
Small things you said, they are really the things Hyundai should work on, and they do. Suspension, break, and handling are nowhere near to those of Japan. (Again, Genesis uses German-tuned/made suspension. I believe it's Porsche)
Overall, they are getting closer to Japanese, but not on par at all. Engine is very very close, but considering other serious parts like tranny and suspension are still outsourced, I think they are still behind Japan, or even behind domestic. (At least Big 3 knows how to make their own tranny and last more than 7 years)
I'm not about to say Korean cars are the best ever, but I take issue with a couple of your 'reasons' why they are not up to par.
Plenty of companies use ZF transmissions. It's not unusual and it makes a LOT of sense for a company to buy in parts like this from specialist companies, especially if it is for a lower volume unit that has to handle higher power than 90% of the units you fit or make in house. Hell, my BMW has a Getrag transmission. I guess BMW suck because they can't make their own manual trans?
Outsourced suspension? You are aware that MANY parts of a car are produced by companies external to the brand name on the hood? The entire dash assembly will probably have been made by an outsourced company, the seats, the headlining, you name it. There is no reason for a car manufacturer to produce or become an expert in EVERY field of production and materials to produce a car. I know of NO volume manufacturer that produces every component under their own roof for one single model. Proton cars have Lotus tuned suspension. That can't possibly make it any worse, it can only be better than an in house solution, otherwise they wouldn't bother (yes I'm aware that it is also a marketing exercise and the relationship with Lotus/proton).
Not only are the parts outsourced, but their components are outsourced by that company. Tier 4 manufacturers (Part is made by company A, then given to company B to add something, then C, then D) are not unheard of.
I'm not talking about little piddly things either. I'm referencing things like the fuel system or brakes.
