Jammed ignition
Feb 4, 2005
124
97 Honda Civic ignition won't turn without a good 2 minutes of jimmying. Had been working fine. Just started acting up. Might be the key. Key works to unlock doors. Got a new key made. New key has same problem but also won't unlock driver side door. Ideas? Thanks.
MrWizzard
2,493
You get your "new" key from dealership or locksmith.
Locksmith keys to newer cars are the bad.
Other than that if the new "official" key doesn't fix it could need a new ignition, something might not be working in it anymore or have gotten in it. They are not usually cheap though.
Heisenberg
10,621
The lock cylinder may be going bad. It's not a big deal to change, but the part itself can get pricey sometimes depending on the car.
CrackRabbit
16,642
62
Originally posted by: etherealgrifter
Is there an easy way to lube the lock cylinder?
Graphite powder spray, for the door locks, I don't know if it would be safe to use it on the ignition though.
Heisenberg
10,621
You can try spraying some graphite lubricant in there. If it's just sticky that will help, but if something is going bad inside then you'll still need to replace it eventually.
Feb 4, 2005
124
Home Depot for graphite spray?
What about removing the cylinder to take it to a locksmith? Do I need an extractor pick for that?
