Small update:
Been comparing some more night shots between the RX100 II and the A6000. In all honesty... it doesn't look good. I fail to see much of a consistent advantage in terms of low light performance from the larger sensor at all. Under equivalent conditions the RX100 II will be able to shoot at a lower ISO and/or higher shutter speed. The aperture advantage of the RX100 is noticeable, the sensor size difference is not.
It's unacceptable to me. There is hardly any advantage to lugging the A6000 and its lenses around. The only pro is the ability to use lenses with shorter or longer focal lengths than the RX100 can manage at acceptable F-stops, but you've got to change the lenses constantly which is a major pain.
I swapped the gimped pancake zoom lens for a Sigma 19mm f/2.8 prime lens that gets great reviews, but again the difference is marginal if noticeable at all. The pancake zoom was plainly worse than the RX100 II at night.
Another swap I've made is to trade in the 55-210mm for an 18-200mm Tamron lens. Still gotta test that one, but so far the sharpness seems slightly inferior. Whether its worth it for the extra versatility is to be seen.
I've had some good results from my daylight shooting in the weekend, but the RX100 performs great there as well.
This thing probably requires Carl Zeiss lenses to properly perform at its potential. Don't bother if you just plan to use budgety ones.
As it stands, I'm ready to throw in the towel and return the A6000 on Saturday. I'm pretty sure what I'm suffering from is mainly a luxury problem; that RX100 II is a force to be reckoned with. But I just can't recommend a camera like this to anyone when there are so much more convenient options available.
Yea, I looked into the sony line for a friend last year, and my conclusion was that the lenses just aren't there.
However, were you comparing jpegs out of camera or what were the conditions of your comparisons? Remember to note that since the sensor is smaller, equal ISO numbers doesn't mean equal noise. Compare the raw files and perform your own noise cancellation on both night shots to see which has more potential.
Welp, the deadline has passed I haven't returned the cam. I don't know what it is about this thing that messes with my mind but I just can't bring myself to return it. No idea what else I'd spend the money on and I do want a better camera, even if this one's a bit of a disappointment relative to my expectations.
The 18-200mm Tamron lens has been fun to use. At least in daylight this removes the need to constantly switch lenses. At the telephoto end it's hard to see a difference in quality with the 210mm Sony one. The sharpness is noticeably inferior to that of my prime lenses but it's all far from unacceptable. It's been a good purchase.
I've got my sights set on two Samyan Rokinon prime lenses. The first is a 12mm ultra wide f/2.0 lens, the second an f/1.4 !! 24mm. Their price is beyond competitive. The catch? They're manual focus only. I'll have to see if that's something tolerable or a deal breaker. Anyone have experience with lenses like that?
I'll probably sell my other prime lenses if these turn out to be good.
edit: oh, another catch: the f/1.4 lens weighs almost 600 grams; think I'll stick with the wide angle one, cause that's just pushing it.
Dxomark also has measurements for the lenses and that's where the difference is massive. The 18-300mm lens gets almost twice the amount of detail at 300mm as the 18-200mm e-mount tamron gets at 200mm. The 30mm lens has f/1.4 aperture and is sharp at that setting. I really don't think I can go wrong with these. But I'll look into renting one, that is a great idea.
Really, I'd be able to tolerate the A6000 if there were good zoom lenses available for it, but if weak 200mm ones are the best I can get, no thanks.
I'll be testing the 18-300mm in daylight on Saturday. I do expect it to shine there. This is by no means a lens designed to handle low light conditions well. Testing of the 18-35mm sigma should happen on Saturday as well.
I'm happy to get any pictures at all at 300mm. Like I said, even if the detail is reduced to 3MP like on tamron lenses, 300mm is overkill. I have the sigma for quality images and the 18-300mm for convenience and telephoto reach. They should complement each other pretty well.Berliner said:Sorry, but that lens won't shine under any conditions, unless you mean shine from CAs.
You will get that. As you would get even better results on a current gen FX, but remember that you asked for jacket-pocket size.All I want is results that are noticeably better than what a pocket camera with a 1 inch sensor produces.
By the way, I've done my research and you're just wrong about the CA. I don't doubt this lens has its set of flaws, but CA is not among them.
12/2 is a great lens. Who cares if it's MF, it's an ultrawide. If you want to use it brain-dead just set it to the relevant hyperfocal distance depending on what aperture you most use (mark it with a piece of tape or whiteout or whatever you want, on the distance scale if you want). (NOTE: The distance scale is non-linear so you may want to do some trial-and-error, taking some test shots, before marking the hyperfocal distance on the lens barrel.)
http://www.dofmaster.com/dofjs.html
For an a6000 + 12/2 the hyperfocal distance is about 12 feet @ f/2.
At f/8 the hyperfocal is about 3 feet.
I just wonder what makes you think the AF is "less advanced". Did you read what the manual has to say about it? There are a lot of AF settings.
