- Sep 11, 2004
- 14
- 0
- 0
Hi There,
I have deployed a web base application using JBoss webserver, it was working fine.
Today I installed tomcat to deploy another application since it was not working, I had to remove tomcat.
I am unable to access the application that i deployed in JBoss, I guess this is because both Tomcat and Jboss use the same port i.e 8080 its showing an error tomcat not found, but I removed tomcat and its contents.
My OS is Windows-XP.
I have tried this options out, deleted all the files that was used by Tomcat and also removed all the contents of registry that was generated by tomcat, even the Path and Classpath settings are fine.
Any clues please help me out, thanks in advance
Cheers,
Tarzan
Cheers,
Tarzan
