Hi all-
I have recently purchased an Iwill XP333-R v2.0 motherboard, and am having serious instability issues. The system randomly crashes often, and each time generates a bugcheck (Win2k Pro/SP2) with a different code each time, usually a "stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL ntoskrnl.exe" or a "stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED win32k.sys"; sometimes it's something totally new.
I've basically assembled an entire new system from scratch, piece by piece, so i have *no* idea which component might be to blame. Is this common for a new system? I get ~5 unexpected blue screens a day, and often programs quit because they generated errors and then won't restart. Pretty soon everything starts generating errors (from winamp to IE to explorer.exe) and I have to *manually* reboot. My system consists of:
Iwill XP333-R v2.0 MoBo (1/16BIOS update, all BIOS settings at defaults, FSB running at 133... though i've tried all of the BIOS versions)
AMD Athlon XP 1800+ (locked, no mods)
2x256MB OCZ PC2700 RAM (2.50V)
ATI Radeon 8500 (w2k_radeon_5_13_01_3276 driver)
Maxtor ATA/133 80GB HD
Pioneer 16x DVD-ROM (DMA enabled)
ThermalTake Volcano 7
Enermax 350W Power Supply
Several case fans
ALI AGP 1.81 Patch (although 1.82 has the same issues)
Help! I'm not sure where to go from here. Do I need a new MoBo? New ram? Different drivers? I'm a newbie, so this is especially frustrating (particularly because I'm having to redo this post since my system just crashed on me... aaaargh!).
For the record, Iwill technical support has been TOTALLY unresponsive, so I'm kinda in the dark here.
Thank you for *any* help,
Darren
Several case fans
Darren
