IWill tiny barebone for HTPC socket 478 and 754 for $157 geeks.com
nairi
306
I was searching around actually for a 1u server case to build a socket 478 HTPC in, but this thing looks awsome, it already has DVI so I can connect it to my TV and have 1080i, only other mother board that i've heard of that has DVI is ASUS and MSI that are from $80-$100. This even has a PCI expansion slot that i'm going to put an ATI HDTV wonder into. hook up a USB wireless adapter put in ur processor, HD, memory, DVD drive and ur set.
socket 478
socket 754
Slick5150
8,760
It says:
# Expansion Slot:
# One AGP 8X slot available
# One Mini-PCI slot
I don't think you're going to fit an HDTV card into a mini-PCI slot
Kelvrick
18,422
Looks decent if you have an ati aiw card.
Wonder if that optical out actually outputs 5.1 or just 2 channels.
nairi
306
yeah ,I just saw that, but the socket 478 has a PCI slot, and no AGP
IlllI
4,927
11
the one review i was able to find noted that if you wanted to use a decent agp card, then you could only use a 2.5 in hard drive. the drive is located directly behind the agp, so there is limited room.
nairi
306
I just noticed that the socket 754 doesn't have DVI out either. So for the AMD guys, ur out of luck. I plan on putting a mobile celeron or my P4 in this thing, so if u have intel then this might be a good deal
EagleEye
982
Hmm, I have an old 2.53 533mhz p4 and ATI 9700 pro (sadly, not AIW). Wonder if this would make a good, cheap HTPC...
Yurkinator
122
The socket 478 one does not have an agp slot, it has a pci slot. Anyone know where to find a slimline optical drive that would work with these?
jumpr
1,045
Geeks has one
Any slimline optical drive would work, though you should get a DVD-ROM drive (at least) if you plan to use this as an HTPC.
mboy
3,309
So this would be decent to use to hook up to a front PJ and use powerstrip to output 854x480 to do a 1:1 Pixel map on my Projector via it's built in DVI?
No gaming, only straight up HTPC, so this DVI is good enough?
Gibson486
18,378
this thing has been on sale since Christams...infact, Geeks.com made it clearence for their new years deal....and they added $10....some clearence that was.
nairi
306
well the socket 478 version has video built in, and i'm planning on using a mobile celeron which doesn't get hot at all. DVI output to a projector sounds like a good idea, besides with the built in video u really can't do any graphic intensive gaming.
AndrewR
Bummer on the hard drive issue -- notebook drives are just too expensive (reference normal drives and vid card problem mentioned above). Seems like a good system if none of the quirks get you on the configuration. Damn, thought I was going to replace my main system with this one! :)
nairi
306
actually u can fit a regular hard drive in there, it goes on the other side of the motherboard where the PCI or AGP slot is. THis is straight from the website:
"Drive Bays:
One 3.5" drive bay for IDE HDD Or Two 2.5" drive bay for IDE HDDs
One internal drive bay for slim line optical drive"
AndrewR
"Drive Bays:
Look at what someone said about regular sized hard drives and larger AGP cards though, above. In any event, I need something with two hard drive bays, and I don't want to be limited to slim line optical drives. I'm cheap that way. ;)
