Iwill KK266 won't POST
RicoJ
66
Just got an IWILL KK266 motherboard with an AMD1.2 but it won't post, it just keeps beeping.. When I opened my case to install it I saw that my Enlight case only has a 230W powersupply.. Could this be the cause?
DaejangNim
710
i had one and it would keep beeping until i changed ram sticks, it only worked with 1 out of 4 working sticks of ram, i tested all these sticks on my other comp, then i took the board back. try getting some different sticks of ram and see what happens, or yours is not seated properly
rempe
158
How old is the case?I havent seen an enlight case with a 230 wat PS in A long time if it is you need to get atleast a 300W PS as for the beeps sounds like ram on the KK266 you really need to slam the ram in hard.This is the number one reason for no post on this board.
RicoJ
66
Rempe,
Yeah the case is about 2 years old desktop case by Enlight. Just don't have enough money right now to upgrade. Thanks for the responsed guys. I will try a stick at a time and see what happens.
Steven the Leech
1,443
Try unhooking all swtches except the power switch too. I had to do that to mine, had em hooked up wrong,the speaker buzzer jumper threw me off. Oh and clear cmos before trying
RicoJ
66
You guys were right... It was the memory.. I pushed in real hard and it works fine now.. Looks like one of my PC100 won't do 133. When I put the board at 100 FSB it detects 256megs if I raise it to 133 FSB it only detects 128megs. I guess it is time to go get one of those PC133 256meg sticks. :)
