I was wondering if anyone else has had this problem and if anyone here knows how to fix it.
Problem:I purchased a Refurb IWill KK266 from newegg.com and yesterday I was trying to hook up my USB MS Intellimouse Explorer (big silver one) in the outer USB slot. It would flicker as if it had some power running to it, but not enough to keep it powered on successfully. I then shut down the computer, changed the USB connection to the inner slot and it worked great.
I'm wondering now, does that mean my outer slot is bad? If so...I'm going to return this motherboard to newegg and hopefully get a replacement. Before using the USB ports, I went into the BIOS and activated both ports under the Advanced Chipset Features.
Does anyone else have this problem or know how to fix it?
T.I.A.
-Kevin
T.I.A.
-Kevin
